oil leak
Has anyone had any oil leaks out there. Gotta leak from what looks like the oil pan seal, but not sure. Some of the bolts on it seemed a little loose too. It's enough that its leaving a spot on the garage floor everyday after I wipe it off. I've got 81000 miles on her, just seeing if anyone else has had this happen.
Mine ended up being 2 seals. On our engines, there is a lower and upper oil pan seal. If you look, the lower part is an aluminum piece. Not really sure why, but both my seals got fixed...it was expensive...but worth it.
, so please "dumb down" your explanation if possible haha
