oil leak
Old Jun 9, 2011 | 10:56 AM
rhinonemec's Avatar
Default oil leak
Has anyone had any oil leaks out there. Gotta leak from what looks like the oil pan seal, but not sure. Some of the bolts on it seemed a little loose too. It's enough that its leaving a spot on the garage floor everyday after I wipe it off. I've got 81000 miles on her, just seeing if anyone else has had this happen.
Old Nov 9, 2011 | 02:45 PM
liveadv's Avatar
i'm experiencing the same issue with my 2007 JKU. Curious if you found any fixes or figured out what the issue was? thanks.
Old Nov 9, 2011 | 03:00 PM
derby911's Avatar
My 08 had an intake leak that was dripping off the oil pan
Old Nov 9, 2011 | 03:07 PM
liveadv's Avatar
where would i look to see if this may be my issue as well, and what is the fix? i've not too knowledgeable when it comes to engines, so please "dumb down" your explanation if possible haha
Old Nov 9, 2011 | 04:49 PM
duneslider's Avatar
If it is the intake manifold, replace your pcv cause you shouldn't have that much oil in the intake.
Old Nov 9, 2011 | 07:20 PM
rhinonemec's Avatar
Mine ended up being 2 seals. On our engines, there is a lower and upper oil pan seal. If you look, the lower part is an aluminum piece. Not really sure why, but both my seals got fixed...it was expensive...but worth it.
Old Nov 9, 2011 | 11:47 PM
JKlad's Avatar
Sometimes the oil from a leaking crank seal can run back & look like it's coming from the timing cover or oil pan.
