Oil Pan Removal
Oil Pan Removal
2015 Unlimited
Dealer sent it to a oil change shop before i bought it and they must have cross threaded the drain plug. 1 st oil change and I find it. So I need to replace my oil pan, no big deal I thought...
Removed the 2 nuts and 12 bolts. I figured a couple of wraps with the hammer would pop it off. No go. Tried a prey bar on a corner no go. What did they seal this with at the factory, JB weld? What am I missing?
Am I supposed to drop the upper pan too? Seriously my next step is a chisel. How has anyone else gotten their's off without damaging the sealing surface?
Once I do get it off I have a fel-pro gasket. I planned to use it without any permatex or what ever. I have seen the gasket sold with an o-ring. What is the o-ring for? Oil filter maybe? I can't think of anything about an oil pan needing an o-ring so I am thinking I do not need an o-ring.
PS I though I had posted this last Sunday so if this is a double post sorry.
You may not like this idea, but consider simply retapping the drain hole and using a fumoto valve that you wouldn't have to remove every time you go to change the oil? Makes life a bit easier too.
Haven't removed a 3.6L oil pan, but on similar have used plastic chisels and putty knives used as a wedge with a hammer. Having had the 3.8L pan off, the lower half is stuck on pretty good as well, and the upper half to the block comes off relatively easy.
I wish mine did. I swear they used JB weld. Mostly want to hear if there was more to it than it is just a pan attached to nothing after you take out the obvious bolts and 2 nuts and it it clear to remove.
That's it. You just take out the bolts and the 2 nuts and it should come off. There shouldn't even be RTV on it. It doesn't need any, just the gasket. There are no hidden bolts or anything else.
I have read that at some point they started using rtv. There is no gasket that I can see. Have to pick up plastic scrapers that look like they're shaped like chisels.
