Sponsored by:
Sponsored by: DashLynx
OK, I Give Up...I can't shift this thing!!
Old 03-17-2008, 10:11 AM
usafa83's Avatar
Default OK, I Give Up...I can't shift this thing!!
First, I've gone through the requisite squeekly clutch fix, etc....
I've had this for six months and I swear I can't take off smoothly in first gear. Its darn near impossible. I've had manual trannies all my life and never this kind of behavior.
Is it the 4.10 gears?
I feel like there is a very small rpm range to make it work. Most of the time I barely give it any gas, let out the clutch, and away I go. But, a very high percentage of times I do the EXACT same technique and I literally squeel the tires, or pop the clutch. Its driving me nuts. I almost feel like the clutch is slipping.
HELP!!!!
Curious to hear some other opinions. THanks.
Old 03-17-2008, 10:15 AM
saltman's Avatar
My Jeep and me have similar issues as you. It is much more difficult to drive than my TJ Rubicon w/ the 5 speed. Of course, it's a whole lot different than the Cayman. I guess it takes some getting used to. I would say the gears don't have anything to do with it. It's the clutch/pedal action.
Old 03-17-2008, 10:16 AM
scouter4life's Avatar
I almost always start in 2nd unless I'm on a slope or pulling something. Seems to be a lot smoother. Other 6 speeds I've driven have been the same way. 1st is almost like a Underdrive (oposite of overdrive) and seems to work best when under more load.
Old 03-17-2008, 10:19 AM
usafa83's Avatar
Yeah, I've heard that here before a few months back...starting in second. Guess I was afraid I'd fry the clutch (doesn't need any help, ha)
Wow... I am so glad I went with the Auto tranny
Old 03-17-2008, 10:20 AM
justinstoffregen's Avatar
x2 -- This is my approach. I think that's why this jeep is a 6 speed. Good luck.
riverzendz's Avatar
When I test drove my Jeep the first thing I noticed was how late the clutch engages.
Old 03-17-2008, 10:24 AM
somewhereinla's Avatar
I test drove a 2dr manual and found the shifting to be very smooth in all gears.
Old 03-17-2008, 10:31 AM
bim6180's Avatar
i've had my 6 speed for over a year now, and always start on 1st smoothly. You might need to have that checked out again.
Old 03-17-2008, 10:32 AM
NE Wrangling's Avatar
I sometimes in cold start situations tend to hit the gas slightly more to get her to go. By habit I jumped into a car with turbo and I peeled out so for comparison ,it's no turbo.
Quick Reply: OK, I Give Up...I can't shift this thing!!
