Ordered new tires tomorrow. Will they be TOO BIG? Help
Old Mar 10, 2016 | 11:37 PM
Jeepersc's Avatar
Default Ordered new tires tomorrow. Will they be TOO BIG? Help
I have a 2008 JKU with stock street tires. Flat, dry rotted, been patched tons of times. 8 years OLD..... It's time to let them go.
And I want something larger... More aggressive. I just set an appointment to install the following on my ALL stock JKU x:
BFGoodrich All-Terrain T/A KO2 (LT285 /70 R17 Will they fit without spacers? It won't do much off-road, hardly any at all.
Old Mar 11, 2016 | 01:13 AM
sa29560's Avatar
Originally Posted by Jeepersc
I have a 2008 JKU with stock street tires. Flat, dry rotted, been patched tons of times. 8 years OLD..... It's time to let them go. And I want something larger... More aggressive. I just set an appointment to install the following on my ALL stock JKU x: BFGoodrich All-Terrain T/A KO2 (LT285 /70 R17 Will they fit without spacers? It won't do much off-road, hardly any at all.
Spacers or adjust your steering stops.
There will be contact with the lower control arms or sway bar if it's not offset correctly.
Old Mar 11, 2016 | 02:32 AM
karls10jk's Avatar
Wheel spacers, lower backspace wheels, or steering stops. You don't need a lift for these tires.
Old Mar 11, 2016 | 06:00 AM
Jeepersc's Avatar
The shop didn't have BFGs like I wanted in stock like their website said they did. So I went with some Cooper A/T tires. 285s and yes they rub on sharp turns. But it sure is an improvement. Click image for larger version
Old Mar 11, 2016 | 02:38 PM
the arrow1100's Avatar
Default wheel size
I run 33 x 12.5 r 17 LT with a rim back space of ~4.5"
No rubbing at all at full lock
On stock 2016 JK sport 2 dr.
I would not do the wheel spacers but get proper back spaced rims if you can wing it.
ID:	640342   Click image for larger version
Old Mar 12, 2016 | 04:06 AM
JerseyDevilJK's Avatar
I have a completely stock 2011 JKUR and just put on 285/70/17 Nitto Terra Grapplers with Helo wheels -4.5" back space and it is a perfect fit with no rub. With your stock wheels you might have to use a 1.5" wheel spacer to eliminate the rub. Its amazing how a little tire size change makes such a big difference on the look of the Jeep. My wife even loves the look.
ID:	640379   Click image for larger version
ID:	640380   Click image for larger version
Old Mar 12, 2016 | 04:54 AM
N2MWL's Avatar
35x12.5x17 on Method NV's 4.75BS no lift..
minor rub at full lock until I removed this thing from underneath the front bumper..
