P0052, replaced sensor, code and engine light still present.
Old Mar 19, 2012 | 09:34 AM
Geko45's Avatar
Default P0052, replaced sensor, code and engine light still present.
My 2007 JK is throwing code P0052 which indicates a problem with O2 sensor 2/1. From reading on another (older) thread here, that should be the top driver's side sensor located just under the steering column.
I replaced that sensor last week, but my check engine light and the P0052 code are still present. I removed the battery terminals and left them off for a couple of hours, but that didn't help. Code and engine light were both back immediately. I've definitely made more than 3 trips since replacing the sensor too.
Did I replace the wrong sensor? Any other ideas on what to try next?
Old Mar 19, 2012 | 09:46 AM
Rich6700's Avatar
Try going to a repair shop that offers free scans and see if they'll reset your ecm.
Old Mar 19, 2012 | 10:42 AM
Geko45's Avatar
Yeah, I suppose I could, but would rather not impose on someone working for a buck with a request for a freebie favor. Like I said, it's been more than three trips anyway. The code should have gone off by now on its own.
Old Mar 19, 2012 | 01:22 PM
ronjenx's Avatar
The sensor isn't the only possible cause.
You did pick the correct sensor, though.
Here is some info for the code you have.
P0052-O2 SENSOR 2/1 HEATER CIRCUIT HIGH
  • When Monitored: Continuously during O2 heater operation with battery voltage between 10.4 and 15.75 volts.
  • Set Condition: The PCM detects that the O2 sensor heater element input is above the maximum acceptable voltage. One trip fault. Three good trips to turn off the MIL.
    NOTE: If P0688-AUTO SHUTDOWN RELAY SENSE CIRCUIT LOW has set along with any of the O2 SENSOR HEATER CIRCUIT HIGH DTCs, all of the O2 Sensor Heater Control circuits need to be checked for a short to battery voltage.
[TABLE]
[TR]
[TD="bgcolor: white, align: center"]Possible Causes
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]O2 2/1 HEATER CONTROL CIRCUIT OPEN
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]O2 2/1 HEATER GROUND CIRCUIT OPEN
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]O2 2/1 HEATER CONTROL CIRCUIT SHORTED TO VOLTAGE
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]2/1 O2 SENSOR
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]POWERTRAIN CONTROL MODULE (PCM)
[/TD]
[/TR]
[/TABLE]
Old Mar 26, 2012 | 06:32 PM
Geko45's Avatar
Just a follow up for thread closure. It took purchasing an AEV ProCal unit to clear the code and get the engine light to finally shut off. Nothing short of that seemed to have any effect. Not even disconnecting the battery for an hour and then doing three good runs after replacing the sensor.
