P0344 code
Old Jun 12, 2014 | 04:36 PM
TacomanBJK12's Avatar
Default P0344 code
Yesterday I got the P0344 code, the traction control light goes on engine light goes on and a red )( with a lightning bolt in the middle goes on the jeep shakes and the gas pedal doesn't do anything, anyone have any help or suggestions for a fix maybe even a possible part number? Thanks all!
Old Jun 12, 2014 | 04:47 PM
ronjenx's Avatar
P0344-CAMSHAFT POSITION SENSOR INTERMITTENT
  • When Monitored: While cranking the engine and engine running.
  • Set Condition: When the failure counter reaches 20. One Trip Fault. Three good trips to turn off the MIL.
[TABLE]
[TR]
[TD="bgcolor: white, align: center"]Possible Causes
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]5-VOLT SUPPLY CIRCUIT OPEN
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]5-VOLT SUPPLY CIRCUIT SHORTED TO GROUND
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]CMP SIGNAL CIRCUIT SHORTED TO VOLTAGE
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]CMP SIGNAL CIRCUIT OPEN
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]CMP SIGNAL CIRCUIT SHORTED TO GROUND
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]CMP SIGNAL CIRCUIT SHORTED TO THE (F856) 5-VOLT SUPPLY CIRCUIT
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]TONE WHEEL/PULSE RING
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]CAMSHAFT POSITION SENSOR
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]POWERTRAIN CONTROL MODULE (PCM)
[/TD]
[/TR]
[/TABLE]
Old Jun 12, 2014 | 04:49 PM
Originally Posted by ronjenx
P0344-CAMSHAFT POSITION SENSOR INTERMITTENT[*]When Monitored: While cranking the engine and engine running.[*]Set Condition: When the failure counter reaches 20. One Trip Fault. Three good trips to turn off the MIL. [TABLE] [TR] [TD="bgcolor: white, align: center"]Possible Causes [/TD] [/TR] [TR] [TD="bgcolor: white, align: left"]5-VOLT SUPPLY CIRCUIT OPEN [/TD] [/TR] [TR] [TD="bgcolor: white, align: left"]5-VOLT SUPPLY CIRCUIT SHORTED TO GROUND [/TD] [/TR] [TR] [TD="bgcolor: white, align: left"]CMP SIGNAL CIRCUIT SHORTED TO VOLTAGE [/TD] [/TR] [TR] [TD="bgcolor: white, align: left"]CMP SIGNAL CIRCUIT OPEN [/TD] [/TR] [TR] [TD="bgcolor: white, align: left"]CMP SIGNAL CIRCUIT SHORTED TO GROUND [/TD] [/TR] [TR] [TD="bgcolor: white, align: left"]CMP SIGNAL CIRCUIT SHORTED TO THE (F856) 5-VOLT SUPPLY CIRCUIT [/TD] [/TR] [TR] [TD="bgcolor: white, align: left"]TONE WHEEL/PULSE RING [/TD] [/TR] [TR] [TD="bgcolor: white, align: left"]CAMSHAFT POSITION SENSOR [/TD] [/TR] [TR] [TD="bgcolor: white, align: left"]POWERTRAIN CONTROL MODULE (PCM) [/TD] [/TR] [/TABLE]
this is what is being read
Old Jun 13, 2014 | 07:09 PM
My biggest question is do I have to flash the computer when I replace the sensor?
Old Jun 13, 2014 | 07:15 PM
ronjenx's Avatar
No need to flash the computer.
REMOVAL - 3.8L
The CMP (Camshaft Position Sensor) (3) is bolted to front of engine. The CMP uses a pigtail wiring harness (2). This connects the sensor to the engine harness.
1. Disconnect negative battery cable.
2. Disconnect electrical connectors (1).
3. Remove sensor mounting bolt (4).
4. An O-ring is used to seal the sensor to engine. Remove sensor (3) from engine by pulling while rotating.
INSTALLATION - 3.8L
If the removed sensor is reinstalled, clean off old spacer (3) on sensor face. A NEW SPACER (3) must be attached to face before installation. Inspect O-ring (2) for damage, replace if necessary. If sensor is being replaced, confirm that paper spacer (3) is attached to face, and O-ring (2) is positioned in groove of new sensor.
1. Apply a couple drops of clean engine oil to the O-ring (2) prior to installation.
2. Install sensor (3) into engine and rotate into position.
3. Push sensor down until contact is made with camshaft gear. While holding sensor in this position, install and tighten mounting bolt (4) to 14 N·m (125 in. lbs.) torque.
4. Connect sensor pigtail connector (1) to engine harness connector.
5. Connect negative battery cable.
Old Jun 13, 2014 | 08:27 PM
No need to flash the computer. REMOVAL - 3.8L The CMP (Camshaft Position Sensor) (3) is bolted to front of engine. The CMP uses a pigtail wiring harness (2). This connects the sensor to the engine harness. 1. Disconnect negative battery cable. 2. Disconnect electrical connectors (1). 3. Remove sensor mounting bolt (4). 4. An O-ring is used to seal the sensor to engine. Remove sensor (3) from engine by pulling while rotating. INSTALLATION - 3.8L If the removed sensor is reinstalled, clean off old spacer (3) on sensor face. A NEW SPACER (3) must be attached to face before installation. Inspect O-ring (2) for damage, replace if necessary. If sensor is being replaced, confirm that paper spacer (3) is attached to face, and O-ring (2) is positioned in groove of new sensor. 1. Apply a couple drops of clean engine oil to the O-ring (2) prior to installation. 2. Install sensor (3) into engine and rotate into position. 3. Push sensor down until contact is made with camshaft gear. While holding sensor in this position, install and tighten mounting bolt (4) to 14 N·m (125 in. lbs.) torque. 4. Connect sensor pigtail connector (1) to engine harness connector. 5. Connect negative battery cable.
Did this post have pics because it shows a broke file logo as the image thank you so much for the instructions I just ordered the part today it should be here Tuesday I was gonna take my jeep down to the coast Monday but it looks like I'm gonna be a passenger this trip :/
Old Jun 13, 2014 | 08:59 PM
Never mind about the pics I went looking tonight for it found it I already ordered the part could it be that the original one just needs to be cleaned then reinstalled?
Old Jun 13, 2014 | 09:19 PM
Confirmation
Old Dec 7, 2019 | 06:54 PM
Snuffcowboy's Avatar
Did you ever get this resolved?? I have the same issue even with a new sensor
