P0349 Camshaft position sensor A circuit intermittent Bank 2 - 2015 Jeep Wrangler 2-d
I hope you can help with this I can’t figure out a solution.
My Check engine light and ESC light go on whenever the engine is under strain. I’m not talking 4 wheeling but it does it on regular roads with a hill. I live in the Utah mountains so this makes it a big problem. The engine code is P0349 Circuit Intermittent Bank 2 Sensor One. Another computer says P0349 Camshaft position sensor A circuit intermittent Bank 2.
At first I thought it was the ESC that was throwing things off. Now I’m convinced it’s the engine code and the ESC shows the Jeep is going into limp mode. If I turn the engine off and restart the ESC light goes off until it hits limp mode again. The engine light stays on.
Here is what happens:
To try and fix the engine light issue:
All this and it is still throwing the code P0349 Camshaft position sensor A circuit Intermittent Bank 2!
I’m at a loss as to what to do next. Any help would be greatly appreciated!
- When going uphill on a highway or a regular road, the engine light goes on soon followed by the ESC light and the engine goes into limp home mode.
- The engine light reads with code P0349 Camshaft position sensor A circuit intermittent Bank 2.
- ABS light does not come on so not the ESC/ABS control module or speed sensors. Plus no codes
- No codes showing the ESC had been on.
- Tracked true and the steering wheel is straight but had a 4-wheel alignment done anyway.
- Made sure all 4 tires had the exact same air pressure.
- Tested the yaw control by whipping around corners and traffic circles. It does not go on and stay on. When triggered the ESC light flashes then goes off.
- Tested in wet conditions. Again, It does not go on and stay on. When triggered the ESC light flashes then goes off.
- I replaced both camshaft position sensors.
- Full tune-up. Plugs, oil, crankcase fluid, differential fluid, etc.
- Tightened the oil galley plugs just below the camshaft-phasers on the driver’s side and used blue loctite
- The battery is less than a year old and all connections are tight and corrosion free
- Changed the pigtail/connector on the driver-side camshaft position sensor – checked and triple-checked the circuit with a meter
- Switched the camshaft position sensors from the driver’s side to the passenger's side to check for a bad sensor even though they were both new.
- Ran a tank of Cataclean
- With each of these, I disconnected the negative battery cable to reset the codes.
The 4 solenoids are the exact same part number. why would you not be able to interchange the exhaust and intake solenoids, assuming you have the proper electrical connections to them?
