P0456 Code, Small Evap Leak FIXED
Old Feb 11, 2018 | 09:36 AM
  #81
resharp001's Avatar
Loved
Community Favorite
Dealing with this dumb code myself now on my '13.....it happens just from time to time....usually with a good length of time in between. Just enough to be annoying. Time to start inspecting the list of culprits....ugh.
Old Feb 11, 2018 | 10:19 AM
  #82
EHarris's Avatar
JK-Forum Ambassador
It's actually pretty easy to play the game and replace. Costs less than $80. Buy all the parts online.
Old Feb 12, 2018 | 05:04 AM
  #83
grandjunktion's Avatar
Originally Posted by EHarris
Start with a new oem gas cap. Then integrity module o ring, then replace integrity module, then purge valve, then maybe evap canister if physical damage is shown to the unit.
Check evap plastic lines that are next to the battery. They sometimes rub.
My theory on this after pulling my hair out is that not many people actually have a leak in the lines. It always comes down to those units specifically the o-ring not making a tight seal. You could play parts roulette with it for the same price as a smoke test or buying the kit from harbor freight to do your own.
what kit from harbor freight are you referring to?
Old Feb 12, 2018 | 12:34 PM
  #84
EHarris's Avatar
JK-Forum Ambassador
Harbor freight has a smoke test for 80 last time I checked. The higher end model was $119
Old Mar 20, 2018 | 10:57 AM
  #85
spartacus_33's Avatar
Default P0456
I had to go QUICKLY from ON to ACC 3 times to get the code. Felt around below the battery, and sure enough I felt a rough spot. I taped it twice. Turned the key to ON and STILL had the check engine light. Reading more of these posts, I found that you must RESET the computer and clear it, by disconnecting the negative terminal. Did that and NO MORE CHECK ENGINE LIGHT.
Thanks everyone.
Old Apr 10, 2018 | 04:27 AM
  #86
Originally Posted by bpittman
Electrical taping every single tube I could find close to the battery under the hood & buying a new gas cap did not solve the problem. Buying these from quadratec solved my problem.
1 51315 0001 MOPAR EVAP INTERGRITY MOD DETECTOR JK 4861962AA 31.00
1 51315 0002 MOPAR VAPOR CANNISTER SEAL JK 52129436AA 5.00
is there a trick to removing /reinstalling the evap integrity module? I couldn't see a clear way to remove it and don't want to compromise the line.
Old Apr 10, 2018 | 10:14 AM
  #87
Jahamm88's Avatar
if my memory serves me right it's just a simple 1/4 Turn to remove
Old Apr 10, 2018 | 01:05 PM
  #88
karls10jk's Avatar
It is a 1/4 turn but you've got to get the tab behind the unit. It's easiest to pull that line off of the unit and then get your fingers in there.
Old Apr 10, 2018 | 02:54 PM
  #89
Sorry I should have been more specific. I can't get the black hosing off the nipple coming off the module. Yes the other side is 1/4 turn with a tab pushed. I got the hose end off by squirting some water on the hosing which is hard and
suffering from the dehydration.
Old Sep 29, 2018 | 05:21 AM
  #90
Micheal Klusken's Avatar
Default Exact
Originally Posted by jqpix
When my extended warranty was about to expire, I took the Jeep (2013 JK Sport Base) to the stealership to have an 87 point inspection. Other than brake pads, the Jeep passed with flying colours. 2 weeks and nearly 1000 Km later (yes, I drive that much), I got the CEL this morning when I started the Jeep.
Didn't have time to check the code, so I went for my assignment and one hour later my reader told me it was a P0456.
I noticed something else:
1. The engine didn't quite sound like it used too, it may be just me but I spend half of my life in that Jeep. Can't tell what the difference is, but is just different.
2. ECO ON won't activate. You may not use the ECO ON feature on the Odometer. It normally reads ECO when you're driving "normally", and ECO ON when you're driving like an old lady. I do my best to keep that thing at ECO ON, not really hard once you get used to it. As long as you have the appropriate gear, it should read ECO ON when you're under 2000-2100 rpm. If you're coasting downhill most definitely you'll get ECO ON. Well, I'm not getting it even when coasting at 60 Kph+. But my OBDC reader still indicates that my fuel efficiency is 0 L x 100 Km (about infinite miles per gallon) when coasting down the hill.
I did a quick visual on the lines by the battery and the gas cap seal and they look good to me.
Got to check again and probably hard-reset the code.
exact same thing on my 2011 what was the fix for this
