P0480 code, further diagnosis inside
2008 Jeep Wrangler Unlimited X
I've been getting a P0480 (cooling fan circuit malfunction) code that started to pop up once in awhile but clearing the code worked (stored code). Now it is an active code. Further diagnosis:
I'm thinking of replacing the whole fan and relay or just replacing the relay.
Any thoughts?
- Fan seems to operate fine. Does not overheat even sitting idle in the hot summer days.
- With vehicle shut off, one can move the fan freely. Seems to be free of obstruction
- Didn't notice any chewed cables in the harness or elsewhere
- Motor housing is rusty but doesn't look damaged.
- No blown fuses in the TIPM
- Doesn't seem to be stuck on the on position. After turning on engine, takes a bit for the fan to turn on, or turn on the AC and it runs as expected.
Any thoughts?
From the '08 service manual...
Are you using an enhanced OBD scanner that will also read codes from the TIPM? If not, see the relevant link below in signature. Additional fault codes will get you much closer to a solution. Both these code looks like generic DTC's that point to looking deeper into the proprietary enhanced codes.
Also, do a domain specific search (google) of JK-forum and the others with that DTC quoted, and see what others with that code have done. For example:
site:jk-forum.com "P0480"
Stay in touch,
P0480 (fan 1 control circuit) or P0481 (fan 2 control circuit)
Set Condition:
The PCM is requesting the TIPM to turn on the Cooling Fan On and it is not operating. One Trip Fault. Three good trips to turn off the MIL.
Possible Causes
Set Condition:
Possible Causes
- CAN C BUS FAILURE
- ENGINE COOLANT TEMP SENSOR DTCS SET
- COOLING FAN CONTROL CIRCUIT DTCS SET IN THE TIPM
- PCM
Stay in touch,
Stay in touch,
Stay in touch,
Thanks again,
-Rob
