P219A diagnoses
P219A diagnoses
Need help diagnosing P219A (air/fuel ratio imbalance bank1) on a 2016 JKU 3.6 with 48000 miles. Showing a handful of misfires on cylinder 1, zero on the other 5. Long term fuel is showing 9.8% on bank 1, 2.6% on bank 2. Short term numbers seem to be a higher percentage on bank but they are also erratic. Like in the screenshot of the frame it's at a negative number, but sometimes it will be a double-digit positive number. Oxygen sensor voltages on each side look consistent, so I don't think it's sensor failing there causing false reading. Fuel mileage is down slightly from 17.5 consistently to 16.5.
I’m leaning toward this being a partially clogged fuel injector, and it dumping more fuel in to compensate. Not much difference in around town driving, but feels like I have to lean into the throttle more on the highway to keep speed.
What is your opinion? I'm not one to throw parts at problem, so I'd like to pinpoint the cause if possible.
Here are the frames from the code.
