Painting underbody rust
I believe Rednroll still uses this method, is in your area, and has good results -
https://www.jk-forum.com/forums/stoc...5/#post4301531
In the end, there is no way of getting around minor maintenance and touch ups if off road at all. Seems like other alternatives I see people talking about are POR 15, or just coating the heck out of the underside with Fluid Film at regular intervals.
I have never had to deal with rust issues as it's just not a concern here in north Texas, but I'm always a little intrigued the extent people have to go to protect against rust in northern areas and the coast lines. I've never quite understood the coating with FF to be honest. I like FF as a penetrating lube for various things, but I've never been able to imagine people spraying or painting it on the whole underside of a vehicle from the standpoint it would seem you'd never be able to touch anything or do any maintenance without feeling like you took an oil bath.
How does that work when a product doesn't dry? I do understand that is what is great about it, but I have a hard time imagining this process. The one thing I'd say is that I could see FF getting in to a lot of nooks and crannies that paint can't access. On the flip side, what I don't understand is that since it's penetrating, how are all bolts not working themselves loose??!! I shot that stuff on my axle side TB heim joint one time, and had issues with that bolt working itself loose 2-3 times from 125ft lbs torque before I finally red loctite'd that sucker.
Anyhow, I'm sure some folks that have to deal with rust will chime in. I'm curious to see if anyone says anything about Fluid Film. Rednroll seems to have a pretty decent track record with his method though.
How does that work when a product doesn't dry? I do understand that is what is great about it, but I have a hard time imagining this process. The one thing I'd say is that I could see FF getting in to a lot of nooks and crannies that paint can't access. On the flip side, what I don't understand is that since it's penetrating, how are all bolts not working themselves loose??!! I shot that stuff on my axle side TB heim joint one time, and had issues with that bolt working itself loose 2-3 times from 125ft lbs torque before I finally red loctite'd that sucker.Anyhow, I'm sure some folks that have to deal with rust will chime in. I'm curious to see if anyone says anything about Fluid Film. Rednroll seems to have a pretty decent track record with his method though.
Also, why can I just spray the rust with rustolum that says spray on rust and it will stop it? What’s the difference?
I have had good luck with the rust reformer. I clean the undercarriage well and use about 4 cans of it each fall on mine. I'll wire brush bad spots. Usually in the corner welds. I never understood using things like POR 15 on something that gets wheeled. It's going to get scraped off. So any strategy that didn't include regular reapplication seemed like a lie to me. $6 a can. $25 a year and it is working well going into my 6th Ohio winter. I have some buddies that use FF. I too am sceptical about putting it on moving or bolted parts or having wax residue to deal with. I may try it on the frame. But only the frame.
Thanks again
I need to post a write-up. I've posted my method many times to other similar posts but never a dedicated discussion thread. That way I can just post a link. I tried to shoot a video this past spring of my process but my phone kept stopping record because I accidently bumped it.
Thanks
