Panel below radio (removal ?)
I want to remove the panel below the radio and do some wiring. I'm referring to the section that contains the vents, heater and ac knobs, plus the power outlets. Has anyone done this?
Eternal ***erator
Someone added LED lighting in there, i am pretty sure there where pics of the work, i will try to find the thread.
That is all one piece from the plastic around the radio to the top of the blank space in front of the shifter.
You have to pop off the top panel and remove some screws then start poppin out the rest of the panel starting at the top.
Its written up here: https://www.jk-forum.com/forums/jk-write-ups-39/removing-factory-radio-706/
