Parking brake change?
Old Aug 30, 2010 | 03:29 AM
Incognito's Avatar
It appears to be the standard type drum brake. That pad looks like it still has some meat on it. Thanks for the pictures.
Old Aug 30, 2010 | 07:22 AM
Northern Wrangler's Avatar
Maybe a dumb question but did you try adjusting your parking brake first? As mentioned those look like they still have meat on them.
Old Aug 30, 2010 | 07:34 AM
Jedi Knight's Avatar
It's not a dumb question. No I haven't adjusted the parking brake yet. I was going to but since I have to do the rear brakes, rotors, and a caliber I figured i'd just do it all at once while I was in there.
Old Aug 30, 2010 | 07:42 AM
spleify's Avatar
Its very easy to adjust the E-brake while you have the rotors off. There is a spring in there with a "star" adjusting screw on it. You can use a screw driver or a brake adjusting tool and turn it to make it tighter. I have had to adjust mine twice already.
I like adjusting it just to the point where it gives resistance when putting the rotor back on, then when it is on I go one more click on the adjusting star. This seems to give me a pretty good brake.
There is a pretty good thread about all of this, I will see if I can find it.
HTH
Good luck
Old Aug 30, 2010 | 07:50 AM
spleify's Avatar
Here you go, pretty much anything you'll need to know about your rear brakes.
https://www.jk-forum.com/forums/show...-parking-brake
Let me know if you have any questions, I have had them off a few times and its all pretty easy.
HTH
Old Aug 30, 2010 | 02:12 PM
Incognito's Avatar
Smile
Damn... nice link
Old Nov 22, 2014 | 09:17 AM
fultonromero12's Avatar
reviving an old thread!
Can anyone tell me for sure if I have to remove the axle rod to replace the emergency brake pads? I narrowed down my awful rear brake noise to the emergency brakes. any suggestions would be helpful.
Old Nov 22, 2014 | 08:21 PM
JTB488's Avatar
No you do not need to remove the axles.
Old Nov 23, 2014 | 04:40 AM
Mark Doiron's Avatar
I remember pulling mine. Did I do something more difficult than needed?
Old Nov 23, 2014 | 08:42 AM
Jiblet's Avatar
You probably made your life easier from the looks of that drum set up.
