Pink Engine Coolant
Old Jun 15, 2010 | 07:18 AM
Super2's Avatar
Originally Posted by plac
BAHAHAHAHAHA this is what the Jeep forum has come to now... so sad. for all of us.
Yeah, I read the Wayoflife posts about all of his troubles and that's got me freaked out, lol!
Old Jun 15, 2010 | 06:25 PM
Rubi 2sday's Avatar
Default Differnce in coolants
Are coolants that different? What could possibly happen if you mix some of the green or orange stuff in there? It can't possibly be like oil and water...right?
Kevin
Old Jun 15, 2010 | 06:57 PM
Any reason you can't go to a dealer and pick some up.
Old Jun 16, 2010 | 01:56 AM
Mark Doiron's Avatar
Kevin
Kevin, you should read the link I posted earlier in this thread. The short answer is, yes, coolants are different and it can result in problems should you mix different types.
Old Jun 16, 2010 | 02:00 AM
Originally Posted by JeepaRoo
you mayt not even need to top it off.. if it is near the MIN when the engine is cold that is perfectly normal....
I filled mine right up to the max line because it was near the min line. Then, while at Moab, I thought I'd developed a coolant leak. In fact, it was just venting out because of moves like this ...
Keep it near the min line if you plan on duplicating such feats of daring do.
Old Jun 16, 2010 | 02:56 AM
Jiblet's Avatar
stolen from h ttp://howtomatthew.blogspot.com/2009/05/types-of-coolant-and-antifreeze.html
IAT coolants are the "traditional green" variety used in virtually all American vehicles from the late 1920s to the mid to late 1990s. Like all antifreeze, it is naturally clear; its color comes from dye. Unlike the other types of antifreeze, it uses silicate and phosphate corrosion inhibitors to protect the metal parts of the engine and cooling system. However, these inhibitors wear out quickly, so IAT type coolants need to be flushed every two years or 30,000 miles.
OAT coolants typically do not use silicate and phosphate corrosion inhibitors. Different manufacturers use different chemical additives to battle rust and corrosion, and they all dye their coolants different colors. GM's ubiquitous DEX-COOL coolant is an OAT antifreeze dyed orange. Toyota, Volkswagen, and Audi all use their own formulas that happen to be dyed pink. Honda uses a dark green dye. OAT coolants have longer service lives than IAT coolants, needing to be flushed every 5 years or 150,000 miles.
HOAT coolants use different additives than OAT, but also use some silicate to protect aluminum surfaces. Modern Ford, Chrysler, and most European vehicles use their own HOAT coolant formulas. Ford's is dyed yellow and Chrysler's is orange (not to be confused with DEX-COOL). Both use the marketing name of GO-5. HOAT coolant has the same service interval as OAT (5 years or 150,000 miles).
Review the chart below for a quick guide to coolant types.
Summary
* IAT - Used in early to mid-late 90's Domestic vehicles
* OAT - Used in late 90's GM and most Asian vehicles
* HOAT - Used in 2000's Fords, Chryslers, and most European vehicles
Coolant Cocktails?
Although you can mix coolant types without harm, it is highly recommended against. If you mix an OAT or HOAT with an IAT, you will lose the extended service life of the OAT or HOAT coolant. Some people say that if you mix these types of coolant it can result in the coolant gelling, but if you keep your cooling system well maintained, this should not be a problem. In general, do not make coolant cocktails!
Old Jun 18, 2010 | 02:36 PM
Super2's Avatar
Thanks again, Mark and Jiblet. I'm glad to have gotten so many good replies!
