play in tail gate
Old Sep 30, 2014 | 02:56 PM
thitalian97's Avatar
Default play in tail gate
it seems i have a lot of play in my tailgate. everytime i hit a bump i hear it rattle. i took off the plastic cover and i see that the bottom hinge has a lot of rust residue coming from the post and that is where i see the play and hear the rattle. do i need to replace the whole hinge or is there another way to fix this problem
Old Sep 30, 2014 | 04:21 PM
Ryan0260's Avatar
Do you have a heavy aftermarket wheel and tire mounted on the factory carrier?
Old Sep 30, 2014 | 06:43 PM
17" aluminum came with, upgraded to 255 spare. running 285 the other 4. never taken the spare off its tight as can be. i saw where a new hinge is like $50 so thats not too bad but would like to avoid even that if possible
Old Sep 30, 2014 | 08:01 PM
71Luber's Avatar
Running a heavier 33, I developed the same problem. Quick fix was to use high bond double sided tape to hold a small piece of heavy rubber hose to take up the slop between the gate and tub right at the hinge. That stopped my rattling about 3 years ago and I haven't done a permanent fix since because it's still working.
With the tail gate closed, you can't see the home made bump stop.
Old Oct 2, 2014 | 08:38 PM
renzo1200's Avatar
Originally Posted by 71Luber
Running a heavier 33, I developed the same problem. Quick fix was to use high bond double sided tape to hold a small piece of heavy rubber hose to take up the slop between the gate and tub right at the hinge. That stopped my rattling about 3 years ago and I haven't done a permanent fix since because it's still working. With the tail gate closed, you can't see the home made bump stop.
Can you post a pic? One of my hinge bolts was loose earlier today
Old Oct 3, 2014 | 03:45 PM
jeepmojo's Avatar
Default you can use a little duct tape
n the latch opposite side of the door or gorilla tape mold it around the latch believe it or not youl never have the problem again
replace the tape every year or so with new , it takes up that tiny bit of slack worked on mine but I did not have rusty hinge
