View Poll Results: What's your odometer reading? Problems??
Voters: 1047. You may not vote on this poll
This is a poll for the JK 3.8L V6 and it's engine longevity. Engine problems so far?
#421
124,000...some issues but nothing too serious
124,000 miles running 35s on stock 3.73 gears
Recently had a passenger side manifold leak so I took the opportunity to replace both manifolds with new headers which immediately shot me a code that my catalytic conv. is failing. So that will be replaced soon. I also have a straight pipe Dynomax Cat-back system with in-line muffler and a Banks CAI. At least when the cat is replaced I'll basically have a brand new exhaust system. The EGR valve also failed so I had that replaced (as was said in another post, having an auto makes for a very hard install). It also burns oil, as expected. Hoping to get another 125,000 out of it.
What do y'all think? Possible to get 250,000 miles out of this engine? I see a few people claim that they have over 350,000...is this for real??
#422
#424
Update to my last post in this thread
Our 2007 Sahara 2 door is up to about 56,000 miles now (yes, a cream puff!). I switched from 10W30 Mobil 1 to 10W30 dino oil a year or two ago and the oil consumption has dropped from less than 1,000 miles per quart to less than a quart in 3,000 miles (Whew!). Sounds fishy but it's true!
Coolant level used to drop very slowly and I couldn't identify any leak. Coolant loss gradually increased to the point that I diagnosed the problem as a leaking intake manifold. I added about half of a bottle of Bars Leaks Copper Seal about a week ago which solved that problem - at least temporarily.
Other than these two issues the old girl has been pretty reliable despite my earlier fears
I had nightmares about bad piston rings, PCV valve, etc., etc.
Not 3.8 engine related but I have also replaced the rear brake pads & rotors, added the MOPAR transmission cooler and an aux fan (for trailer towing), and just bought a set of Sahara takeoff tires & rims to replace the OEM's (MUCH cheaper than buying a new set of 18" Dueler A/T's - I also have a set of Rubi takeoffs for wheelin').
#425
2008 76k on it, replaced EGR, PCV, water pump, clutch, front upper and lower ball joints, gas cap a few times, blower for heater, and it slurps oil. 1 quart per 1000 miles at least. Also transmission sucks, often enough it is hard to get into a few gears like 4th for example and pops out. I know there is a dealer notice but getting them to work it considering I have life time power train is hard as I am not giving them money.
#426
2008 with ~58K miles on it. Pretty low miles for a 2008, but sometimes time is a factor as well as miles. All the preventative maintenance done per the manual, and except for oil changes (5w-40), usually a bit early. The only problem I'm remembering is a PCV valve that I suspected was sticking open intermittently (there was a code that led me to that conclusion, and the problem did not re-occur after replacing it).
However, there was one exception which was not a Jeep/Chrysler issue, a tuner glitch that mal-programmed the PCM and required a new PCM to get it back to normal. That still ticks me off: Even before it failed during programming, there wasn't any improvement, then craptacular customer service from Diablosport followed by a large bill from a dealer (because only a dealer has the computer tools to program a blank/new PCM). Needless to say, it will be a cold day in hell before I use a tuner again.
#427
2008 with ~58K miles on it. Pretty low miles for a 2008, but sometimes time is a factor as well as miles. All the preventative maintenance done per the manual, and except for oil changes, usually a bit early. The only problem I'm remembering is a PCV valve that I suspected was sticking open intermittently (there was a code that led me to that conclusion, and the problem did not re-occur after replacing it). However, there was one exception which was not a Jeep/Chrysler issue, a tuner glitch that mal-programmed the PCM and required a new PCM to get it back to normal. That still ticks me off: Even before it failed during programming, there wasn't any improvement, then craptacular customer service from Diablosport followed by a large bill from a dealer (because only a dealer has the computer tools to program a blank/new PCM). Needless to say, it will be a cold day in hell before I use a tuner again.
#428
I feel like my tuner took the lag out of the pedal. But yes, I use it to log data from the jeep to help with code diagnosis.
#429
My 08 has just under 100 thousand and so far just the 3.8 oil consumption. Not to bad yet about 1 1/2 quarts per 10 thousand mile oil change. I use Mobil one extended mile synthetic and am very happy with it. I do drive it pretty hard and I run it between 3000 and 4000 rpm's. I forgot about the exhaust manifolds both have been changed.
#430
