Possible soft top leak fix
So my top started leaking by the passenger side door the other day during a big rain storm. Today when I was nice out enough to work out side I investigated why it was leaking. I took a water bottle and poured it all over the door and then ran to the driver side to see where it was leaking. I noticed it dripped on the inside door handle. So I opened up the door and saw nothing odd as in a crimped or torn wheatear seal. I popped the top and notice foam lining the outer edge of it and foam lining where it meets where it closes. The foam looked a little worn out so I replaced it with foam I had at work the seals off bed caps. After I was done I again poured water all over the door and no leak!!!! I'll how long this hold out I'm hoping I fixed it!
This is the foam I was talking about before I replaced it
The biggest problem is the C-Cup. Where the header sits into the that C-Cup that is connected to the door. It is just an awful design. I did this to fix it this past weekend. I don't know if it's working yet, but It's raining really hard right now, so I'm about to find out.
So my top started leaking by the passenger side door the other day during a big rain storm. Today when I was nice out enough to work out side I investigated why it was leaking. I took a water bottle and poured it all over the door and then ran to the driver side to see where it was leaking. I noticed it dripped on the inside door handle. So I opened up the door and saw nothing odd as in a crimped or torn wheatear seal. I popped the top and notice foam lining the outer edge of it and foam lining where it meets where it closes. The foam looked a little worn out so I replaced it with foam I had at work the seals off bed caps. After I was done I again poured water all over the door and no leak!!!! I'll how long this hold out I'm hoping I fixed it! <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=546693"/> <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=546695"/> This is the foam I was talking about before I replaced it
