Power Control Reflash
Had my 10 Rubi 6spd. in on an oil change and they did a reflash. There were no issues going in and no difference that I can detect going out. The only way I know that they did it is because they told me Chrysler wants it done and they listed it on the service invoice. Again, I can't tell that anything has changed.
Look at the Invoice / paper work of what was done to your jeep. It should have this on it :
JK 3.8L OBD READINESS PCM FLASH
181906H5 Module, Powertrain Control (PCM)
Reprogram Module, Powetrain Control (PCM)
Flashed PCM
Hope that helps
Here's what they did to my 10 Rubi 6spd.
Reprogram Module, Powertrain Control (PCM)
Everything was fine prior to the reprogram and it seems the same now. I can't tell that there is a difference. Probably since it's a 6spd.
Originally Posted by Tuto
For what a being reading people with manual trans can not notice a difference. Only in the Automatics you can notice the change/improvement.
I have an Automatic.
Brings to mind how I'm supposed to find some of this stuff out. I'm doing all my own maintenance so far, 20100 miles. I do drop into the Jeep owners factory site every couple of months to run my VIN and it comes up clear. May have to drop by the stealership and ask them to run the VIN.
