JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   Stock JK Tech (https://www.jk-forum.com/forums/stock-jk-tech-12/)
-   -   Power steering fluid? (https://www.jk-forum.com/forums/stock-jk-tech-12/power-steering-fluid-136416/)
Hellbound13 Jul 12, 2010 07:44 AM
What kind does the JK use? Is it ATF 4. If so can I just get any ATF 4?
ronjenx Jul 12, 2010 01:57 PM
Yes, any ATF+4® will work.
Hellbound13 Jul 12, 2010 04:36 PM
Thanks. Will I need an alignment after swapping boxes?
rinkishJK Jul 12, 2010 04:39 PM
Re: Power steering fluid?
U will only have to center wheel. Toe and caster r not affected. Was it a hard job hellbound!??
Sent from my Droid
Hellbound13 Jul 12, 2010 05:10 PM
Sent from my Droid
Dunno haven't done it yet. Will let ya know tomorrow! :thumbsup:
Also is the pitman arm keyed or do I have to pay attention to where it mounts on the splines of the sector shaft?
ronjenx Jul 12, 2010 06:19 PM
The instructions in the service manual are vague. It doesn't say much about indexing the input or output shafts. No mention of a master spline.
Center the steering system
Index both shafts on the old one before anything is disconnected.
Make sure the new box is centered.
See if it looks like the splines line up the same on both boxes.
It probably isn't too critical as long as you get equal turns left and right after all is done.
Hellbound13 Jul 12, 2010 08:52 PM
Thanks! :thumbsup:
ronjenx Jul 12, 2010 09:05 PM
Do you need torque values?
Hellbound13 Jul 12, 2010 09:11 PM
The bolts that hold the box are 80 ft lbs. and the sector shaft nut is 185? Any others?
ronjenx Jul 12, 2010 09:30 PM
Install a new coupler pinch bolt and tighten to 36 ft. lbs.
Install power steering hoses/tubes to steering gear and tighten to 27 ft. lbs..
© 2026 MH Sub I, LLC dba Internet Brands
