Proper jack points?
I'm going to be doing my own 5 tire rotation soon as was just wondering what are the proper jack points? Should I just jack the axle housing up for whatever tire I am changing? Or is there a better method? Using a standard floor jack.
Originally Posted by Dronac
I use the differential for my 3 ton jack, and put stands on the ends of the tubes. I use a lubelocker seal and havent had any issues. I dont think anywhere else would reach with a 3 ton jack.
It's lifting the front that's the tricky one because the diff is off centered so you slide have to go at 2 points or do one side at a time. My old cummins I'd risk lifting on the axle tube but I'm a little leery with the jeep cuz it's so new and a buddy of mine already had to replace his front axle after hitting a creek bed too fast with his 2012
You use the diff in the front? It's lifts crooked as a dogs hind leg
