Purpose of manual shift with automatic transmission
My 2012 JKU Altitude came with the manual shift on an automatic transmission. The gear shifter on the console has a +/- symbol that allows you to shift gears manually. What's the purpose of this?
so you can control your shifting. In straight auto mode your computer determines the shift points in manual mode you control the rpms to shift at. Kind of like a manual without a clutch.
Alanymarce (01-12-2024)
FrickrFrackr (01-10-2024)
It is disabled until you tap the shifter left or right. It is a necessity if your doing any off roading. If your going down hill and need to keep a slower pace you use the lower gears of the trans so you are not riding the brakes which will cause your rotors to heat up too much and warp as well as having to replace pads sooner.
