puttin some rubi stuff on sahara? ?
Old Apr 12, 2011 | 09:31 PM
ctjeeper's Avatar
Default puttin some rubi stuff on sahara? ?
This weekend im getting stock Rubi rims and stock BFG MTs for my 07 Sahara unlimited along with Rubi shocks and springs. Now my question is when I go to install the springs and shocks should I put some spacers in while im at it, in effect giving myself a lift? If so what size front/back? I don't know how long ill have to stick w/ just stock Rubi tires, but could be a while before I have $ to upgrade. So id like a height that looks good with them, but might fit bigger in the future, if that's possible. Btw, mostly daily driving, w some light offload use. Thanks for any input...
Old Apr 12, 2011 | 09:49 PM
dinojeep's Avatar
Might as well as long as your in there. Throw a rubicon sticker on there too.
Old Apr 12, 2011 | 10:04 PM
ctjeeper's Avatar
If the Rubi coils are a higher number than your sahara coils then they will give you a little bit of lift. If they are the same or lower number then don't bother swapping them in (for obvious reasons). I wouldn't worry about the extra spacer now because to put it in there in the future is cake.
Jack up by the axle, remove tires, put stands just behind the CA mounts, disco sway bar, take out the bottom bolt for the shock, drop the axle. The coils will pop right out. No need for taking off the track bar or brake lines, there is flex room.
Eh, guess im gonna scrap the springs. Just checked. Fronts are the same as mine. Backs are 58 vs my 56. Guess I just assumed it would be a bit more of an "upgrade" than it is. Thanks!
Old Apr 12, 2011 | 10:20 PM
hitman21988's Avatar
how do you find out what you have?
Old Apr 12, 2011 | 10:29 PM
ctjeeper's Avatar
Crawl under and hopefully the tag is still on the springs. Look at the last 2 numbers
Old Apr 13, 2011 | 05:43 AM
ctjeeper's Avatar
Don't scrap the springs, I would rather try to sell them- someone has 12s and needs an upgrade......
Yea, I meant scrap the idea, ill resell the springs... liked yer video, btw. That road flood often, I take it?
