rattle under dash
Old Nov 9, 2010 | 06:58 AM
addison06's Avatar
Default rattle under dash
Im getting some type of rattle underneath the steering wheel and kinda under or behind the glove compartment in jeep. It only seems to happen when at higher speeds....70-80mph.
Ive checked as I was driving to make sure there wasnt anything loose but cant seem to figure out what it is. Anybody had any issues like this, or have any ideas what it could be.
Only thing done recently was went to 33's and 2.5 inch lift
Old Nov 9, 2010 | 04:03 PM
Scooter09JK's Avatar
I have the same rattle, same speed
I cannot figure it out as well
Hope someone can help out...
Thanks,
Scooter
Old Nov 9, 2010 | 04:13 PM
Brick-JK's Avatar
Same here , seems to be coming from the driver's side
Old Nov 9, 2010 | 04:15 PM
spleify's Avatar
I had the same rattle, it started when we did Red Cone and Radical Hill, drove me fricken nuts that day. I pulled the lower plastic dash panel off and there was a big metal box, I believe it was like Infinity or something like that, I assumed it was for the stereo or something. Anyway, it was not bolted in, it was just kinda sitting in the pocket there. I threaded in a couple of bolts and that fixed the problem.
I dont know if this is what you guys are hearing but might be worth a look.
HTH
Good luck
Old Nov 9, 2010 | 04:55 PM
Badd Andy's Avatar
the "Infinity box" is the systems amp, mine was also loose and rattling around under the steering column, I just zip tied mine tight, no more noise
Old Nov 9, 2010 | 06:23 PM
ssg381's Avatar
Its a jeep.. just gotta get used to it.
Old Nov 10, 2010 | 05:59 AM
addison06's Avatar
HTH
Good luck
Thanks I will have to check it out. If I turn Radio up loud enough I cant hear it anyway. LOL
Anyway
Thanks for suggestions
Old Nov 10, 2010 | 05:15 PM
RST JK's Avatar
I have the same noise.....not all the time, but always when above 60mph or on a really windy day. My thought is that maybe it's the front air dam smacking the frame. Noise travels in weird ways, but I havent tried removing it to see if the noise goes away.
Old Nov 10, 2010 | 05:21 PM
Don't think it is the "air dam" as I have replaced mine with a skidplate and noise is still there
I am thinking it is something in the door/panel that rattles with the wind, hence only at higher speeds/windy conditions
Thanks for everyones suggestions
Old Nov 10, 2010 | 05:36 PM
Bri's Avatar
Bri
I have the same rattle in my jeep. Starts at about 40mph. Its a real light rattle. I'll have to try strapping the Infinity amp down. Thanks for the help.
