Rear brakes wore faster than front
Old Dec 14, 2013 | 05:46 AM
  #21
Mjp83's Avatar
Originally Posted by Jiblet
Did you bed-in the new pads or just drive off? Different brands make different recommendations on the process.
I just picked it up from dealer.....did not know about some "break in" procedure! Tell me more.....thanks!
Old Dec 14, 2013 | 06:07 AM
  #22
karls's Avatar
They should have done the break in, but it varies between manufacturers. Hawk says 6-10 mild stops from 35 and 2-4 harder stops from 50.
Sent from my DROID4 using Tapatalk
Old Dec 15, 2013 | 04:33 AM
  #23
Krumby's Avatar
Would better brake lines make the brakes better ? We are talking about the brake lines that connect to the caliper right ?
Old Dec 15, 2013 | 05:01 AM
  #24
tcdawg's Avatar
Replacing rubber brake lines with stainless steel is an upgrade to your braking system. The rubber lines can expand a little under pressure, the SS won't. If you are completely stock as far as weight and tire size you may feel a little difference. If you have larger tires and lots of other weight you may not feel any improvement. Most change to SS brake lines when they lift yo get a longer line for there new flex
