Rear wheel came off at 65mph!
Old Apr 5, 2013 | 04:10 PM
Delux2769's Avatar
I rotate my tires everytime I do an oil change. I check my wheel spacers at that time as well.
Old Apr 5, 2013 | 04:12 PM
JustPlaneSweet's Avatar
Good plan! Does double duty.
Old Apr 5, 2013 | 05:40 PM
SRJeep's Avatar
Are you guys that run spacers using extended lug bolts?
Old Apr 5, 2013 | 06:32 PM
TikiBob's Avatar
I believe you are thinking the old style spacer. The new style/better spacer are more of a adapter. Put spacer on stock studs and have new studs offset for the wheel.
Old Apr 5, 2013 | 06:55 PM
SRJeep's Avatar
I understand, you are correct, I was thinking of the old style.
Old Apr 5, 2013 | 09:02 PM
CharlesS's Avatar
Not to be negative, but it sounds to me as though someone may have loosened the lug nuts either as a get even or trying to steal them.
The sheered studs happened when the last loose lug nut fell off.
Here is my story......
Many years ago I left a friends home around midnight and discovered later that someone tried to remove my rear 14x7 chrome Cragar SS rims. Driving ar 45 mph the rim came off, car dropped to the ground and tire went by me off the side of the road. Checked the other tire and the nuts were loose too!!
Lucky I had traction bars so ther was no damage to the brakes.
My brother came by with a floor jack and spare tires.
Old Apr 6, 2013 | 07:10 AM
Ryan0260's Avatar
Good thing you are ok. That could have been a very bad situation.
Old Apr 7, 2013 | 11:40 AM
red98tbs's Avatar
Vet Army
Same experience as Charles above. Back in the early '70s I was at the movies with the girlfriend. Came out of the show about 2 hours later, jumped in my 340 Duster and headed home. Got about half a mile down the road and Bang! the left rear drops down as the tire and wheel go past my window. Some scumbag had loosened the lugs on both rear wheels, but couldn't get the locking lugs off. Makes for a real thrill ride for a couple of seconds. Got the hook from an FC Jeep wrecker!
Old Apr 7, 2013 | 01:29 PM
JK_Crawler's Avatar
Originally Posted by JustPlaneSweet
I just got back from the dealership. They say the holes in the wheel that came off are too wallowed out for the wheel to be safely used. I had them swap it with the spare until I find a used wheel (someone who took off the factory wheels for aftermarket).
What do you think? In order for the holes to be wallowed out, the lug nuts must have been loose for a time. I guess checking the lug nut torque needs to be in the oil change routine. I am surprised I did not notice a shimmy or clunking or something.
Stan
From reading this post I can say the lugs came loose, this is common when wheels aren't torqued to spec or when there not torqued in a star pattern. How many miles does your jeep have? Also do you have aftermarket lugs on your jeep? I ask about mileage because Chryslers lug nuts absolutely suck! They are a 2pc design and usually the outer portion of the lug nut will swell and can spin causing the nut to not be torqued properly. Also if you have aftermarket lug nuts "tuner lugs" they could of been your problem as well. These are designed for aftermarket wheels but they are just terrible lug nuts period. A lot of people buy them thinking they are " locking lugs" but are mistaken, they are all splined the same and do nothing for security. I see a lot of issues with these lug nuts on stock wheels, most common being coming loose from normal driving.
Old Apr 7, 2013 | 01:34 PM
robsjeep9's Avatar
JK-Forum Ambassador
What's the proper torque? 90 ???
