Rear Wheel Won't Come Off
Old Mar 13, 2011 | 09:24 AM
el mono's Avatar
Default Rear Wheel Won't Come Off
Seriously, what am I doing wrong? Tire's off the ground and lug nuts are off. Corrosion?
Old Mar 13, 2011 | 09:54 AM
sa29560's Avatar
That sounds like a predicament. Just loosening my lugs is a pain. I always check them when I fill up. They are so tight by the time I take them all off.
Could you get a pry bar in between the wheel and center for some leverage???
Old Mar 13, 2011 | 09:56 AM
SIDsjeep's Avatar
Veteran: Coast Guard
my friends tj has the same problems. we usually soak the area with some wd40 and with a large rubber mallet and a hi lift jack handle you can pry it off and combo of hitting the wheel. i hope its a help. and if your really ballsy you can try letting it down off the jack and drive it a small distance like 3 feet back and forth and then jack up to see it its better. like i said very dangerous but interesting to watch some one else do this.
the last part was us thinking outside the box when the typical things didnt work so it may help you out as well. good luck
Old Mar 13, 2011 | 10:16 AM
Olean NY Jeeper's Avatar
Just take a large rubber mallet and whack the sidewall of the tire to loosen. You could also try using a metal hammer and tapping the wheel to loosen, just dont all crazy with the metal hammer. I would think that getting a large pry bar and prying up between tire and driveway would help like ur checking ur ball joints up front.
Old Mar 13, 2011 | 10:20 AM
Biginboca's Avatar
I've never had this happen, but I would be surprised if a few good kicks to the tire wouldn't get it loose...
Old Mar 13, 2011 | 10:21 AM
Ario56's Avatar
DO NOT hit the sidewall with rubber mallet! That sucker can bounce back twice as fast as you swung it and in a crazy direction. I watched a guy knock himself in the head. Pretty funny once we figured he was ok, but I wouldn't want to experiance it.
Hit the rim from behind. Spin it while you're hitting it to knock it off evenly.
Put anti-seize on your hubs when putting the wheels back on to prevent further headaches.
Old Mar 13, 2011 | 10:24 AM
well I wasnt suggesting that he put his head behind the hammer and swing like superman, guess I should have specified.
Old Mar 13, 2011 | 10:27 AM
wazooz2424's Avatar
give if a few kicks with your foot. should break loose.
Old Mar 13, 2011 | 10:29 AM
did u get it off yet?
Old Mar 13, 2011 | 10:33 AM
Ario56's Avatar
I was just saying a rubber mallet on a rubber tire filled with air can take an unpredictable trajectory. I recommend against it.
