Rear window straps? 2012 soft top unlimited
I have had my JKU Sport for just over a week now. Loving this great Md weather when its not raining and had the top open the other day. I wanted to roll up the rear window for some more air flow. I noticed in the glove box there were 2 elastic straps that have a snap on them. They fit snaps on the top of the support bar above the rear window. It is basically an elastic loop with a snap on it. I can post a pic if needed. I remember a different setup on my 95 Rio Grande soft top. Question is, how does this work? Zip up the window, roll it up, and wrap these around it and secure to support bar? Seems like a more complicated method then i remember on my YJ.
I leave the elastic straps snapped onto the soft top, and when I roll up the back window I just unzip each side of the window to a point just inboard of the snaps on the top, roll the window up (carefully), and then stretch the elastic around the outside edge of the roll on each side.
This seems to work fine for me. I've tried it that way both with and without the window bar attached to the rear window.
I'm not sure if this is the "manufacturer-preferred" method of doing it, but it works for me.
eventually those elastic straps will stretch and lose their elasticity and you have to double it up around the rolled up window to keep it tucked up high and out of the way.
how do the straps scuff the windows? my rear window is scuffed or cloudy looking, but i never thought it was from the straps. i used to take my rear window off and leave it at home too, but sometimes it's such a pain putting that damn thing back on.
Around here our bright, sunny summer afternoons are interrupted by thunderstorms more often than not (although you can usually see them coming 30 minutes before they get to you). Leaving the windows at home isn't something I like to do except for very short trips.
The rear window bounces around when in the straps, any dust or dirt on the strap or the window will slowly cause marks, only took a couple trips to make marks on mine the strips should have been lined with a microfiber cloth or something from the factory
