rear wiper delete
lets put it this way...the very first mod i did on our JKU was take out the rear headrests and brackets. she still complains about the view out the back. next i flipped the mirror...still a comment about the back window. next will be the rear wiper assembly. after that i'm mounting a rear view camera with a 42" TV in the dash for her to see.
she had problems backing up our TSX with a back up camera so i'm probably screwed regardless. but it gives me an excuse to take something apart.
I took her to a neurologist but unfortunately they said everything was normal for a female...
What did you guys use to plug the holes? I just found some plastic caps that I was going to put a bead of silicone around.
She claims that it is because she is only 5"0' tall and all the cars back then were so big (pre '73 oil crisis) that she could never see out the back of them; maybe, but the above neurologist analogy seems the likely cause...
Originally Posted by mister ed
turns out its a moot point anyways...
didn't bother to check the actual glass and didn't notice it was black at that portion. oh well. now its cleaner back there.
what did you guys do with the harness and washer fluid line? i don't mind cutting the washer line but maybe not the harness.
Originally Posted by jjntj2003
what did you put in the holes? part number, grommets,??????
As far as grimey back window...I squeegee is every time I film her up. And now the wife just doesn't drive the jeep anymore!
