Recommended Diff Fluid for rubicon
I read a couple write ups, but want to be 100% sure on what weight gear oil to use for the rear Rubicon axle.
I read to use Royal Purple 75W90 Synthetic Gear Oil.. is this correct..?
How many quarts do I need?
Do I need any special oil for the lockers?
Any help would be great.
According to the write up the front takes 1.35 quart and the rear takes 2.375 quarts. I just changed mine again this past weekend. I also use Royal Purple. You don't want to over fill the diffs. It will run out the breather tubes and smell to high heaven for a couple of weeks. Found out the hard way the first time I changed them. No problems this time though.
