Remove fuel line
I have looked but I cannot find an answer. I am removing the fuel tank and there is one line I cannot get loose. It is the line that connects from the top of the round white thing on the top of the tank and goes with the filler line (wire ties) it has a white piece of plastic that I think you nee dto push or something any help would be appreciated.
Took me a while to disconnect fuel line, saw a set of two tools at Harbor Freight the other day--had to learn how to manipulate to disconnect--it is a snap together fitting--you use the tool to depress a snap ring inside the fitting--snaps together when reconnecting--BW
Found fuel line tool at any auto store or harbor freight it is plastic you push it in and pull hose apart. I had to remove the fuel tank and skid so I could install brackets for rock sliders.
