removing Jack 2011
haha...I did the same thing. Then I turned the piece where the crank goes into to close the jack and it came right out.
The jack is partially opened as the previous poster stated to keep it from moving so you want to close it and collapse it more
If the 2007 is like the 2011 you should be able to just stick a screwdriver through the jack hole on the end and twist it and that should begin to compress it enough to be able to pull it out
