Removing the 'Warning' Visor Decals
Old Feb 8, 2011 | 12:27 PM
wmphoto's Avatar
I just got some black sports tape and taped over them. It's next to invisible now...
Old Feb 8, 2011 | 12:43 PM
Mark Doiron's Avatar
Originally Posted by toad
As far as I can see, there is no getting the newer ones off. They are hot-pressed on there. I would suggest putting another decal over it or just dealing with it.
Someone should offer a decal that matches the interior color and texture. That would teach them lawyers!
Old Feb 8, 2011 | 12:50 PM
ohboyX3's Avatar
yep, it's a real pain to get the '10 off. I have an '08 and just pulled them off. I replaced the visors last week with '10 and got the decals off.
It takes steam. I took a steam iron. covered the visor with a piece of felt and held the steaming iron about a 1/4 inch off of the surface. most of the decal pealed off pretty quickly. the remaining decal was difficult, but it came off.
about 30 minutes overall. the visor was not damaged... but i did not touch the visor with the hot surface.
good luck...
Old Feb 8, 2011 | 01:43 PM
briancarter's Avatar
On my 08 JKU I just took the driver side and switched it with the passenger side. That way the stickers are facing up where you can't see them until you lower the visor.
Old Feb 8, 2011 | 04:45 PM
OoPEZoO's Avatar
Hot day in the summer, and mine peeled right off with no residue left. Not sure about the newer ones.
Old Feb 8, 2011 | 04:49 PM
GreenJK07's Avatar
Mine warped from the heat so I pulled them off and used goup to take off the adhesive. Much better!
Old Feb 9, 2011 | 05:18 AM
senfinger's Avatar
So this worked on the 10'/11' ? Might be interested in doing this or at least trying- You can def start to pick at a corner as if it's raised. Just need to find out if it will lift up-
good luck...
Old Feb 9, 2011 | 05:33 AM
ohboyX3's Avatar
yea, i tried to pull the '10 off... i tried for about an hour and got very little removed. i made it look bad enough, i had to find a way to get the rest off. i tried a hair dryer, but it really didn't do anything.
then i tried steam. this worked... it was a pain, but it worked.
Old Feb 9, 2011 | 05:44 AM
cybersymes's Avatar
good luck...
hey there...innertesting post...good fix on the stickers...
did you get the newer visors 'cos they are bigger...
as i have thought of doing this...
is it as easy as it sounds...and is it worth it...cheers.
Old Feb 9, 2011 | 06:14 AM
ohboyX3's Avatar
yes... my wife wanted a mirror... they are larger and slide... there are several threads on the forum. but, the stickers are attached in a totally different manner than the earlier models.
