Replaced water pump leaking worse
Old Sep 26, 2013 | 12:43 PM
Bronco_Bustin's Avatar
Default Replaced water pump leaking worse
I replaced my waterpump because of a small seep at the gasket by the bottom bolt that was leaving pink streaks on my oil pan.
I replaced it Tuesday, have driven about 30 miles and checked it is leaking worse from 3 different spots at the gasket. I scraped the gasket surface clean and torqued to 105 in-lb...
What now?
Should I try to torque the bolts down a little more? Since the gasket it wet does that mean it is already shot?
Bought the pump from Napa and noticed the gasket was a tad skinnier than the stock one. Didn't use any rtv cause the stock gasket didn't appear to have any
Old Sep 26, 2013 | 01:00 PM
jk.bushwacker's Avatar
since you know the water pump is new, try a new gasket and reinstall. they are like $6. hope you did not scratch or gouge sealing surfaces... good luck!
Old Sep 26, 2013 | 01:02 PM
myrojk's Avatar
Rtv ftw just sayin
Old Sep 26, 2013 | 04:06 PM
familytime's Avatar
JK Forum Regional Rep
Take it off,dress the surface with a file to make sure the surface is flat,then reinstall with new gasket
Old Sep 27, 2013 | 03:00 AM
Mark Doiron's Avatar
Originally Posted by Bronco_Bustin
... I scraped the gasket surface clean ...
I find it's a good idea after using a razor blade to scrape off any old gasket material, to lightly dress the block seal surface with 220 grit (or so) emory cloth/sandpaper. Then, use Permatex The Right Stuff on both sides of the new gasket. If you reuse the gasket that is on it right now, make certain it is completely dry first. And use the Permatex very thinly--you don't want a glob of it to get pressed into the cooling jacket where it might gum up something when you torque the pump into place. Don't substitute anything for The Right Stuff: Use that--it is expensive, but amazing at sealing and holding the seal.
Oh, you can just pull the water pump without draining anything else. Put a clean bucket directly below the pump, on a plastic sheet to catch any splashes. You'll drain about 1-2 quarts. Replace that into the radiator directly--not into the overflow reservoir unless the radiator won't take any more. Before installing the pump, ensure the surface is dry. Daub out any coolant that might drip in the way. Use brake cleaner to completely clean and dry it off.
Old Sep 27, 2013 | 03:48 AM
Yankee's Avatar
This right here. Is the surface aluminum? Have to be careful if so.
I would check the surfaces, put in a new gasket using a little Permatex.
Old Sep 27, 2013 | 06:16 AM
Neilfeed's Avatar
It won't hurt to check the bolts first check them cold an then again hot. But it's probably gonna need a new gasket mine did the same thing with the cheap gasket that came with the pump I got a new feel pro gasket and put some red grease on right before I put the pump on it swells the gaskets and helps seal Good luck!
Old Sep 27, 2013 | 01:21 PM
smokeman's Avatar
bought the same pump. gasket that came with pump leaked. replaced with new "felpro" gasket. no more leaks.
Old Sep 27, 2013 | 01:29 PM
wrigley's Avatar
What now?
Did you torque in a "criss cross" pattern?
mike
Old Sep 30, 2013 | 11:47 AM
I find it's a good idea after using a razor blade to scrape off any old gasket material, to lightly dress the block seal surface with 220 grit (or so) emory cloth/sandpaper. Then, use Permatex The Right Stuff on both sides of the new gasket. And use the Permatex very thinly
Thanks for the advice, I am just going to buy a new gasket anyways, and try lightly dressing the surface as suggested... I've never heard of the "Right Stuff", did Chuck Yeager use it? Lol
I have the Blue RTV at home but I'll check out this right stuff when I'm at Napa
Also good to know about just pulling the pump and saving some of that $20/gallon coolant
I just used the flat edge of a razor blade, I feel like it would be hard to do by hand
Hand tightened criss-cross, then torqued criss-cross
