Resetting the Check Engine light
Old Feb 6, 2018 | 09:22 PM
Cayt1324's Avatar
Originally Posted by yomondo
If I remember correctly, it goes like this:
1. Turn the ignition on, but don't start the engine.
2. Press the gas pedal to the floor quickly and back all the way up three times.
3. Turn the ignition off, but leave the key in.
4. Start the engine.
thanks this worked!!!
Old Feb 7, 2018 | 06:34 AM
TrailBadger's Avatar
Former Member
That's news to me as I've been aware of the oil change reset..
Old Apr 26, 2018 | 02:08 AM
Ronniebgr's Avatar
Default This Method works
This method works for my Jeep Commander .
Thank you
Old Dec 11, 2018 | 12:56 PM
Mlahiff's Avatar
Default Great tip for engine light reset
Originally Posted by kidkoala
5. Pass go
6. Collect $200
The ignition key and gas pedal instructions worked perfectly. Thank you.
Old Dec 24, 2019 | 01:26 PM
JasonVideo's Avatar
Default Check engine light still on
I know this thread is old, but seems like the best place.
Mine was throwing a P0128 code. I changed the thermostat and housing. Drove it. Still throwing the same code. I did the 3 gas pedal trick. Check engine light still on, but when I check the code I just get - - - done--- Wonder if the sensor is bad (temperature). Or if the light will clear after a few more trips?
Weird.
Jason
Old Feb 13, 2020 | 06:05 PM
Ed Garzaro's Avatar
Weird.
Jason
i have the same issue. I think this is a common issue and it is insanely annoying. I have to get my admissions test in the next few months and a check engine light will trigger an immediate fail.
Old Feb 14, 2020 | 04:58 AM
resharp001's Avatar
Loved
Community Favorite
On our JKs, if if you change the thermostat, it's often just a good idea to change the coolant sensor at the same time. They are common to fail and its often tricky to determine if the code is due to thermostat or the sensor. They don't cost much so best to just change them both.
I hope you score well and are accepted based on your "admissions" test results
Old Dec 7, 2023 | 01:32 PM
bg25's Avatar
How did you get rid of the P0128 code after replacing the thermostat housing. I replaced my thermostat housing and did a coolant flush and my check engine light is still on.
