rubi springs and shocks...good deal?
Any input on these fellas? I have an 08 Sahara, currently has a TF spacer level.
If it's a good deal, do I have to ditch the TF setup? If the height will be the same as with the 2" level I'd just keep the level as I don't really wheel.
http://tampa.craigslist.org/hil/pts/3980203333.html
Just because they springs came off a Rubicon doesn't mean they are going to be of a higher rate. How the Jeep came out of the factory and with what options determines what springs they get.
Cliff notes: Always ask for the spring numbers.
Nope "rubi springs" don't mean squat. Spring Numbers is what you want to look at. I wouldn't waste my time unless you're going up at least 2-3 numbers on each end. That being said, I've seen better deals. Is it $150 shipped?
Check the numbers, if you have a 2 door and their off a 4 door you will def gain 1"-2" of lift. As for the shocks and ride I would imagine that it would be stiffer than your sahara stock. I have a rubi and think it rides fine( a little stiff) but if your saying you dont really go off road you might not want to go this route.
