Rubi or X
Of all the things you get on a rubi, the transfer case, lockers and front Dana-44 axle are what should be your make/break decision.
The other stuff you could install on an X pretty easily and for the cheap.
The transfer case on a Rubi will let you go into 4-lo and just let the Jeep crawl over most stuff without giving it much throttle or go down steep inclines without pressing the brake much.
The transfer case on the other models requires a little more throttle and a little more braking.
However, I can vouch on my own that the transfer case on an X will descend a pretty steep slope (went up and back down a steep mountain logging trail) without hardly touching the brakes if you just put it into 4-lo and first gear on your shifter.
Just food for thought.
