Rubicon Spring found in rear diff
Old Mar 3, 2014 | 09:15 PM
briteod's Avatar
Default That's the bugger
That's the one it was broke in two pieces attached to the drain plug. The weird part is NO leaks?? Im thinking on just waiting till I see a leak to do anything. Any idea why it would break?
Old Mar 4, 2014 | 06:38 AM
JeeP_MarK's Avatar
There are many reasons why they can break . Most due to age or work load. Since its not leaking it's most likely broken from manufacturing defect or was damaged when the axle shafts were installed from the factory . The spring is there to put tention on shaft as the seal wares. If it's not leaking as you said there's no point changing it , it could be months or years before it fails
