Seriously?
Old May 1, 2011 | 04:40 PM
jpthunder's Avatar
Default Seriously?
So I noticed a little condensation in my tail light and took it off to clean it out, and look what I found. I took a pic of the hole right over the rear tire that allowed this to happen. Piss poor engineering if you ask me.
ID:	155788   Click image for larger version
ID:	155790   Click image for larger version
Old May 1, 2011 | 05:01 PM
HornetJK's Avatar
P o w e r w a s h e r ! ! ! It must have been fun causing that thou!
Old May 1, 2011 | 05:04 PM
JK.nick's Avatar
Yuck! Now I wanna go see what's behind my tail lights.
Old May 1, 2011 | 05:12 PM
Four Low's Avatar
Post
What is that stuff? It looks like expanding foam , but is it just good old dirt?
Old May 1, 2011 | 05:19 PM
itasor's Avatar
I took mine off to change bulbs the other day and they had huge clumps of road salt all over them.
Old May 1, 2011 | 05:21 PM
wmcvey's Avatar
I have had both of my tail lights out before. Don't remember seeing any holes, or at least they were covered over by some rubber type of material that is there.
Old May 1, 2011 | 05:30 PM
dreads83's Avatar
It's a jeep. Dirt will find its way into any place if you use it.
Old May 1, 2011 | 05:44 PM
dillUSMC's Avatar
i took mine off to extend my breathers and there was a foam pad and the bottom of the tailight compartment, check to see if its missing
Old May 1, 2011 | 06:51 PM
txjeeplover's Avatar
I also have foam pad covers in the lower of the taillight compartment. The compartment isn't sealed but certainly closed off to mud and debris. If you're not the original owner, it's possible it was removed before you got it or maybe removed by someone running wires for something in the back.
Old May 1, 2011 | 07:43 PM
Sierra141's Avatar
That expand foam is not factory, I took off mine a 2010 rubi and it's empty clean.
Looks like someone was trying to waterproof or seal it from the elements.
