Shaking at 55...
Old Dec 22, 2013 | 02:27 PM
offroadtimmy's Avatar
Default Shaking at 55...
I have a 2010 JKUR with a 2.5" lift and have a pretty good shake a 55mph. Tires are all balanced ( says the dealer ). Any thoughts?
Jeepstin12's Avatar
let me guess. Goodyear tires?
Old Dec 22, 2013 | 02:44 PM
crusaderJK's Avatar
x2 ....I'm in the same boat
Old Dec 22, 2013 | 03:03 PM
FDHog's Avatar
I'm turning 60 next month and haven't started shaking yet
Have your alignment checked.
Old Dec 22, 2013 | 03:53 PM
Jiblet's Avatar
That's textbook balance symptom.
Methinks the dealer is wrong...
You could've thrown a weight since the dealer balanced them. Or did the dealer check for balance AFTER you noticed the shake??
You could swap in the spare and test various positions.
Old Dec 22, 2013 | 04:35 PM
Sporticon's Avatar
Re balance the tires
sent from the slow lane
Old Dec 22, 2013 | 04:51 PM
Factory tires. BFG MTs
Old Dec 22, 2013 | 05:08 PM
Jeek.OlllllllO's Avatar
Same thing for me just need to re balance or it's time to rotate your tires
Old Dec 22, 2013 | 05:38 PM
When I test drove the jeep before I purchased, it was shaking the whole time. They balanced the tires and now it only shakes at 55. I wound up knowing the guy that traded the jeep ( friend of a friend of a friend ) and he had 35s on it. Put the stock tires back on to trade it in. He said the 35s ran smooth.
Old Dec 22, 2013 | 06:06 PM
Jeepstin12's Avatar
still yet, a balance issue. I would have the dealer rebalance the tire. The tech still places the weights which could off set the balance, regardless of the method they are using. Weights all inside/outside the wheel for instance.
