shudder
Old Aug 13, 2013 | 03:33 PM
elrodmg09's Avatar
Default shudder
Ok, I have a 2011. Every once in a while when shifting between gears higher than 2nd, I'll hear a sputter from the exhaust, feel a shudder and hesitation, and then it will go. This has happened at least 6 occassions. It goes away after a new tank of gas and/or some Sea Foam. Of course I attributed it to bad gas. I started sticking to certain gas stations and quit having the issue. Then I moved. It just started again, so I took it to the dealership today. Of course they saw it is lifted so they say it is a driveline issue due to my lift and won't do warranty work. I have a 2.5 inch lift and know enough that my pinion angle shouldn't be much of a problem at that height. Plus it did it before the lift. I explained this. No luck. I explained that I doubt it is driveline if it goes away with fresh gas or treatment. They still say driveline. I feel this is a cop out on the service department's part. On the way home the Sea Foam finally kicked in and the issue is gone again. I use premium gas and am tuned for 91 plus. It did this before the tune, also. Any thoughts?
Old Aug 13, 2013 | 03:51 PM
kjeeper10's Avatar
Vet Army
I would pull and check the gaps on the plugs.
That's BS... If you need warranty work go to another dealership.
Old Aug 19, 2013 | 06:03 AM
elrodmg09's Avatar
I'll do that. Didn't even think to check plugs as they've never been changed and I just hit 16k.
