Single Chime randomly on startup
Old Oct 18, 2010 | 08:31 PM
PCHSahara's Avatar
thx for all the feedback!
its not the seatbelt..when i unclick..the chime/light goes on right away.
its not tmps..i lowered 1 tires pressure today and when i started car..the chime, and indicator went on. once i filled it back up and tried again, it properly no longer alerted...
its not gas level either..full tank
it could be oil..i should be due soon based on my mileage..but usually when its oil change time the dummy message is on screen every time you start the engine as well as when you turn it off...
Old Oct 26, 2010 | 03:04 PM
interceptor_1972's Avatar
Any update on this? This still happening? Or were you able to narrow down the cause to a particular item?
Old Oct 26, 2010 | 03:17 PM
madmax92104's Avatar
change oil? press the gas pedal 3x before you put your key in and then start it and see if it continues.
Old Oct 26, 2010 | 05:00 PM
Wangler's Avatar
I haven't had my Jeep for more than a few months, so....
Does a JK have a low temperature warning? My last car would chime if it was 3ēC or less when I started it.
