Single "ding" with oil change light at startup
That is not the change oil indicator, that is the oil pressure light.
The oil change indicator actualy says "Chang Oil" in the digital display
Most likly a faulty sender but may want to get that checked out in case it really is low in oil pressure as if your oil pump is about to fail you'll pop your engine when it does.
What viscosity of oil you using? 5W20 or thicker I hope.
Wanted to see if there was something I could check before having to take it to the dealer; it gets to be a pain to have to drive 35 miles to the nearest Jeep dealer and have to restore the Hypertech programming back to stock, etc.
Just to be sure it isn't the OCI light, and I dont think it is....turn the key to ON position but don;t start it. Then press the gas pedal all the way down 3 times in rapid sucession. Then start it and see if it still does it. If not, that was your issue. If it is still there, it wasn't your problem
Only difference is mine does it every cold startup.
The one time I used a Mobil 1 filter instead of a Fram, I got the tick/knock on every startup on my 07 Sahara Unlimited, not just after the first start after the oil change. Figured it was draining back given the horizontal orientation of the filter. Installed a Fram. No more tick/knock. I would strongly suspect you got a filter with a faulty anti-drain valve. That's why your oil pressure light stays on a little longer, it takes longer to build pressure with an empty filter. Try a new filter, it's cheap insurance considering how much an engine rebuild would cost. If you still have the receipt maybe the parts store will do an exchange.
But perhaps OP was unlucky and got a defective oil filter blocked enough to reduce oil flow to the point as to trip the sensor. Very unlikly but maybe.
I would change the filter waiting til next oil change could damage the engine every time you start it has to reprime the pump because the filter is draining back into the pan. If it were mine I would just buy a new filter and change it then top off the oil to replace what is lost
Perhaps cheap insurance but not for the anti drain issue as I use them all the time and never get the oil pressure light using the same 5w20 sythetic oil OP does.
Guess I'll cross that bridge when I get there.Thanks for all the input guys. Will try it this afternoon/evening and see if anything's different. Will post back the results.
UPDATE:
Replaced the Motorcraft filter and decided to go with a MOPAR filter, and topped off the oil. Figured, if changing the oil filter does not solve the issue, then a trip to the dealer for some warranty work is in the near future and didn't want them saying "replace the oil filter" line. I guess, tomorrow'll tell if this solves the problem or not.
Again, wanted to thank everyone for their suggestions. Y'all are a great bunch!!!
And the result............
Well what do we know... With the Mopar filter on, this morning - no more "ding", no more "oil light" and guess what else was missing when I cold-started it??? No more engine tick/knock at cold startup either
So, while I'm not sure what is different between a Mopar filter and a Motorcraft FL-739 [which, and I've double checked this, also has an anti-drain valve], it is apparently significant enough to cause the single "ding" and the oil pressure light to flash and for the engine to have a tick/knock during cold startups. I'll keep an eye on it over the next few days and weeks to see if this did indeed completely fix the issue, or if it just masked it. But I must say - it sure was a nice feeling to hear the JK start up without any racket [even if it only was for a couple of seconds] or the light flashing and getting a ding
. I almost half expected it to do it when I started it this morning!
So, again, a big thanks to everyone for their suggestions and tips. This is what makes this forum such a wonderful place to hang out at!!!
