Small and large and GASCAP
The check engine code is for a Large Evap Leak and Small Evap Leak. The evap is part of the emissions system which performs a self check every certain amount of miles.
The problem with the Small Evap Leak (gas cap leak) occurred a few years ago on my '11... Instead of replacing the gas cap I decided to clean the sealing surface of the filler neck with throttle body cleaner and wipe the gas cap O ring with water and apply a slight coating of grease. The code has cleared.....
Upon closer inspection this appears to be alright.
I check all of the connections running to and from the gas tank, evap canister and filler hose. Everything appears to be ok. I cleared the codes and immediately all of them came back within 3 min of driving the vehicle.
I feel like this would be something major disconnected or obvious.
OK this is a great link I found in another post. I know throwing money at it isn't the answer but I can get parts at cost.
So looking at this diagram....Is there anything anyone recommends trying that would be all 3 codes immediately after clearning?
Vapor Canister and Leak Detection Pump
