So I accidentally went along a ditch and ended up in a muddy field... NEED HELP ASAP
Well if you're sure there is no water in the cylinders and you're sure you are not getting gas then it has to be either the electrical feeding the pump, the pump itself, or the fuel lines. I'm not sure what exactly is involved in the electrical feeding the pump but the easiest (cheapest) thing would be to start tracing the electrical and fuel lines. If you can confirm getting power to the pump and fuel lines are intact and not clogged then that would narrow it down quickly.
Troubleshoot...
https://www.jk-forum.com/forums/jk-e...-relay-274779/
Troubleshoot...
Your feedback indicates a fuel line problem.
Do so at your own risk : when you disconnected the fuel line (hopefully u placed it in a bottle to catch any leaking fuel) did you crank the engine ? Did any fuel spurt out (into the container) ?
One answer (of many possible) is that you crushed or caught a fuel line or wiring to the fuel pump when off-roading into the ditch.
Did you go over any tree stumps or rocks ?
why do people beg for help ASAP then not respond
to those who try to help ( instead just vanish from their own thread ) not even taking the time to say they found issue or not. wack jobs :
ignorant !
ignorant !
because they post the same question of 4 or 5 different forums and their mom probably took away their internet access LOL.
