Soft top door surround knobs are $20 each?
Old Apr 24, 2010 | 11:22 PM
xerofall's Avatar
Default Soft top door surround knobs are $20 each?
I have a stock hard top. I bought the Bestop safari top combo that came with the duster, extention and windjammer about two years ago. This was before I knew to come here and really do my homework. Anyway... come to find out the safari top doesn't really look good when you have the doors on because I didn't have the surrounds. The duster didn't seal at the rear because I didn't have the rear bar either.
Flash forward a year and my inlaws ask me what I wanted for Christmas. My wife says door surrounds and rear tailgate bar from Quadratec because she really knew how much that bothered me. Nearly $400 bucks not including shipping for these bad boys. For essentially 4 big hunks of plastic.
I finally get the weather to cooperate and open up the boxes to install the surrounds and they didn't come with any hardware. You have to buy the knobs seperately. So I go back online to Quadratec and find them for $20 bucks each. My guess is that I need 4 of them. Another $80 bucks, just for knobs!!!
No way. There's got to be an alternative. I'll have to try a nut and bolt store because both my local Lowes and Home Depot didn't have anything that long.
Any suggestions?
Old Apr 26, 2010 | 06:34 PM
xerofall's Avatar
Anyone got any suggestions?
Old Apr 26, 2010 | 06:38 PM
brandon07jk's Avatar
ace hardware should be able to het what you need its a pretty big hard ware store also i think napa carrys nuts and bolts
Old Apr 26, 2010 | 07:56 PM
robctry69's Avatar
ace hardware does have them i think i spent about 5 bucks for 4 bolts and washers and worked perfect i wasnt going to spend 40 plus shipping
Old Apr 26, 2010 | 08:02 PM
xerofall's Avatar
Okay... there are only 2 ACE hardwares locally. I'll check them out.
Old May 2, 2010 | 07:43 PM
xerofall's Avatar
Went to Ace. Picked up four 4 inch posts and some nuts and wing nuts, screwed them in this morning and it moved the surrounds into the proper position... all for $10 bucks!!! Screw $80 for the Mopar ones!!!
I wanted some knobs instead of wing nuts... but they didn't have any... however since I'm only putting the safari top on once or twice a year, it's not bad.
Thanks for your help!!!
Old May 3, 2010 | 06:25 AM
OoPEZoO's Avatar
Good.......the Mopar knobs suck anyway. The first time I tried to remove the surrounds on mine, two of the four knobs stripped out and I had to remove the shafts with a pair of vise grips. This was the VERY first time they had ever been touched. I ended up filling the knobs with some epoxy, heating the shafts with a torch and reassembling them. I have since had to do the same with the other two as well. They stripped out when removing them on a hot day. After the heat and epoxy, they are holding together fine. They are a stupid design and I think you made the right choice of hitting up the hardware store instead
Old May 3, 2010 | 06:29 AM
Full-Traction Suspension's Avatar
Former Member
i was going to suggest finding jeep junkyards and calling them
daveysjeeps.com usually has odd things like this
Old May 5, 2010 | 06:25 PM
chris15005's Avatar
On mine the knobs seperated from the shaft of the stud i think it cost me 4 bucks in stainless bolts and washers from the hardware store
Old May 6, 2010 | 08:36 AM
pgreen822's Avatar
Are you guys referring to the knobs that you use to connect the plastic window/door frames when putitng the soft top on?
If so, there are two types of knobs.... one is longer (maybe 2"?) and the other is shorter (about an inch). I currently only have 2 long and 1 short, so I believe I am missing just one of the short ones. Can anyone confirm? I currently have my hard top on and will be putting the soft top on in a few weeks. If I am just missing the short knob, can someone let me know the part number and where I can get one cheap?
Thanks!
