Soft Top Question
Old Dec 12, 2010 | 10:54 AM
matt852's Avatar
Default Soft Top Question
Okay so you know how you can run a "moonroof" configuration with the soft top. Well everytime I take the plastic windows off and make it so that its a "moonroof" with the top on the legs of the top end up flying away because it's not tight enough. Are we suppose to be able to run the "moonroof" with the windows out? Or is it suppose to be moonroof with side windows on and rear window out only?
Thanks
Old Dec 12, 2010 | 11:39 AM
sciguy6's Avatar
I'm not sure what's up with yours but I have driven highway speeds like what you did and I don't have a problem. I'm sure someone will have an answer for you. (I won't be trying it again for awhile as it's 20 degrees and snowing with 50 mph winds.
Old Dec 12, 2010 | 12:30 PM
matt852's Avatar
Are you a two door or a four door?
