Soft top rear window question
What's the best way to roll up my rear window and prevent it from getting scratched? Someone suggested that I roll a soft towel up between the layers but wouldn't that increase the weight on those elastic straps and decrease their life?
Suggestions?
Suggestions?
I don't have a good suggestion for you but my '15 rear window is somewhat cloudy-scratched where it rolls up and the elastic loops chafe it. I think the biggest issue is dirt/dust as the loops rub against the window material but I don't see anyway to prevent dirt from getting on it even if you clean the window before rolling it up mine draws road dirt dust up onto that area as you drive.
They make a storage duffle for it. You unzip both side windows and the rear and roll them up in felt pages then store that in a bag that hangs from the rollbars in the back under the folded top. I love mine. Only wish I got it sooner. I got one to keep it from getting worse but it was already pretty bad.
I actually roll my back window down. Then I use one of the Velcro straps for the sunrider to keep it rolled tight. Mine is a 2012 2 door and I don't think it's that scratched up. I like that I can drop the top right on it. Then I slip the side windows between the backseat and the top.
I just got a soft top, so no experience with window storage. However, my first attempt so far is to use 4" PVC pipe cut to 53". The rear window and tailgate bar are rolled up in a thin fleece blanket and slid into the PVC pipe. The pipe fits under the rear seat.
Curious on how you've done it. Got some pics?
I made a duffle for mine but lately I have just been unzipping the rear window and just letting it fall into the rear storage area, leaving the tailgate bar attached. Hasn't scratched yet. When removing the side windows too I use the duffle.
My take is a bit different. On my last JK, I tried all sorts of ideas to keep my zip-out windows from getting scratched/clouded. Every idea eventually became a hassle. On my current JK, I found that I'm much happier just letting them get scratched up as I constantly take them off/roll them up.
