soft top zipper ?
First time having a soft top do u guys do anything to prepare it for winter like anything with the zipper or anything I should look out for any advice is awesome
Don't unzip your windows if it's below like 50*. Yes, you can still do it but the chance of breaking a window increases. When it gets closer to freezing it is even more likely for a window to crack. And for the zipper I use cheap bar soap to lube it up.
Just rub the soap on the inside of the zipper, like where your salami would go if you've ever accidently got it caught in the zipper. Just rub it on the inside edge there. I've done it and it had smoothed out a sticky zipper.
