Spare Tire Mount
Old Jul 19, 2011 | 06:54 AM
baz0157's Avatar
Default Spare Tire Mount
anyone know if the spare tire will mount on after a 35 in tire has been mounted on a factory 17 in wheel?
Old Jul 19, 2011 | 07:09 AM
Paul R's Avatar
It will fit height-wise but will touch the indent of the bumper and slightly block the CHMSL. If the tire is much wider than the stocker, you may need to put a wheel spacer on.
Old Jul 19, 2011 | 07:11 AM
The_Yeti's Avatar
i guess it depends on the width of the tire and if you bought after market tail gate bump stops
Old Jul 19, 2011 | 01:53 PM
baz0157's Avatar
thanks guys ... I wasn't sure and didn't want to buy the tire yet if it won't go on...
Old Jul 19, 2011 | 02:24 PM
CherryRed11's Avatar
My old neighbor had his fall off....I wouldn't recommend it.
Old Jul 19, 2011 | 03:16 PM
OH9JK's Avatar
JK-Forum Ambassador
The "official" weight capacity of the OEM tire carrier is 50 lbs.
I weighed my factory Moab with factory BF Goodrich 32" tire and it is 69 1/2 lbs.
Think about that one for awhile......
Old Jul 19, 2011 | 06:40 PM
jason0341's Avatar
That's crazy because my 315/70/17 Duratrac on stock 17" Moab is only 67.5lbs
Old Jul 19, 2011 | 06:47 PM
Blakspire's Avatar
It also depends on the backspacing of the wheel.
Been running my 35*12.50*17 Toyo M/T's and Raceline Renegade wheels with the spare in the stock hangar for over a year. I don't even want to weight that combo.
Did I mention I live in Alaska?
I'm a believer.
Its amazing how much of the JK accepts 35's from the factory.
Old Jul 19, 2011 | 06:50 PM
D_engel's Avatar
I weighed mine at 72. if you wheel hard with stockers, you may have just as many problems as someone with an oversize spare
Old Jul 19, 2011 | 06:51 PM
SlackerMD's Avatar
Stock rubi BFG MTs were just about 48lbs + close to 22lbs for the 17in rubi moabs...i know the duratracs are relatively light, but that size has to be at least 10lbs heavier (my 285/70r17 duratracs are about 53lbs alone)
